Zyxel 660HN-T1
- Trials
- IPv6 Trial
- Zyxel 660HN-T1
Zyxel 660HN-T1
07-06-2011 8:00 PM
Settings attached, but I think I'm probably going to give it up as a bad cause. I've not tried tweaking much on my local machines as I don't suppose there's much point if the WAN side isn't being assigned an IPv6 addy?
Re: Zyxel 660HN-T1
07-06-2011 8:15 PM
Re: Zyxel 660HN-T1
07-06-2011 8:22 PM
Re: Zyxel 660HN-T1
07-06-2011 8:29 PM
Can you get connected on IPv4 with that username? Try that first and then start trying the IPv6 stuff.
Re: Zyxel 660HN-T1
07-06-2011 8:36 PM
Re: Zyxel 660HN-T1
07-06-2011 8:53 PM
Also make sure you enable DHCP Prefix Delegation (DHCP PD) on the WAN settings page.
Plusnet Technology
Re: Zyxel 660HN-T1
07-06-2011 9:00 PM
Re: Zyxel 660HN-T1
07-06-2011 9:02 PM
Plusnet Technology
Re: Zyxel 660HN-T1
07-06-2011 9:19 PM
Re: Zyxel 660HN-T1
07-06-2011 9:32 PM
Has the PC picked up an IPv6 address? It might be delegating out but not assigned the WAN correctly. You could try filling in the IPv6 address boxes.
Prefix is 56, IPv6 address I would guess at something like 2a02:16c8:2000:5000:5267:f0ff:feeb:0304
Plusnet Technology
Re: Zyxel 660HN-T1
07-06-2011 10:12 PM
Quote from: dave Has the PC picked up an IPv6 address? It might be delegating out but not assigned the WAN correctly. You could try filling in the IPv6 address boxes.
You mean the ones at the top of the first screengrab in the preceding post?
If so, tried that and ran an ipconfig. Doesn't look promising to me, but then as per my first post, I doubt I'll get anywhere anyway without a WAN side IPv6 address.
Ethernet adapter Atheros L1 Gigabit Ethernet:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Atheros L1 Gigabit Ethernet 10/100/1000Ba
se-T Controller
Physical Address. . . . . . . . . : 00-1B-FC-8E-9A-A2
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IPv6 Address. . . . . . . . . . . : 2a02:16c8:2000:5000::2(Preferred)
Lease Obtained. . . . . . . . . . : 07 June 2011 21:57:06
Lease Expires . . . . . . . . . . : 07 June 2011 23:57:06
Link-local IPv6 Address . . . . . : fe80::9d1c:661c:2623:9b06%11(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.33(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 07 June 2011 21:57:07
Lease Expires . . . . . . . . . . : 10 June 2011 21:57:06
Default Gateway . . . . . . . . . : 192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.254
DHCPv6 IAID . . . . . . . . . . . : 251665404
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-13-11-C0-06-00-1B-FC-8E-9A-A2
DNS Servers . . . . . . . . . . . : 192.168.1.254
Primary WINS Server . . . . . . . : 192.168.1.254
Secondary WINS Server . . . . . . : 192.168.1.254
NetBIOS over Tcpip. . . . . . . . : Enabled
Re: Zyxel 660HN-T1
07-06-2011 10:16 PM
so it's getting something.
Plusnet Technology
Re: Zyxel 660HN-T1
07-06-2011 10:28 PM
Whilst the WAN status still shows no WAN side IPv6 address (it's blank), it certainly looks like something's working now!
C:\Users\Bobby>tracert ipv6.bbc.co.uk
Tracing route to ipv6.bbc.co.uk [2001:4b10:bbc::2]
over a maximum of 30 hops:
1 1 ms <1 ms <1 ms 2a02:16c8:2000:5000:5267:f0ff:feeb:304
2 30 ms 29 ms 27 ms 2a02:16c8:0:1::1
3 28 ms 29 ms 27 ms 2a02:16c8:1:8000::1
4 27 ms 27 ms 27 ms 2a02:16c8::5
5 27 ms 26 ms 28 ms 2001:7f8:4::1ad7:1
6 27 ms 27 ms 27 ms 10gigabitethernet1-1.core1.lon1.he.net [2001:7f8
:4::1b1b:1]
7 29 ms 38 ms 30 ms 2001:7f8:4::c8d:1
8 222 ms 208 ms 58 ms cr0-gi1-2.thdo.ipv6.bogons.net [2001:4b10:0:8001
::1]
9 28 ms 28 ms 28 ms ipv6.bbc.co.uk [2001:4b10:bbc::2]
Trace complete.
Re: Zyxel 660HN-T1
07-06-2011 10:35 PM
No idea why the WAN side doesn't work, maybe Mark who has the same router has had different results.
Plusnet Technology
Re: Zyxel 660HN-T1
07-06-2011 10:53 PM
