Withdrawl of IPv6 Technical Trial
- Trials
- IPv6 Trial
- Withdrawl of IPv6 Technical Trial
Re: Withdrawl of IPv6 Technical Trial
11-10-2012 4:55 PM
I'd love to say we are ready for this and it is something that is being moved on, but there are priorities, some of which are dependencies for us to do IPv6 (the reason the trial stopped was deployment of kit that was a dependency).
It's coming. A traditional Plusnet acronym for this is RSN - Real Soon Now.
15-01-2013 1:33 PM
I see you have started the CG-NAT trial to get around the lack of IPV4 addresses. I can't do that as I need incoming connections, so am keen to try IPV6.
Gareth
15-01-2013 2:09 PM
24-01-2013 11:34 AM
In either case I'm pretty keen for native IPv6 as well.
24-01-2013 2:43 PM
Given the prevalence of always-on connections these days the difference in loading on address pool availability between dynamic and static assignments is pretty much insignificant.
However, whilst PN might not currently be experiencing any issues with address exhaustion this will not be the case forever hence the trial.
21-03-2013 10:02 AM
Were there problems with the trial? If it was working for the trial, why not let customers choose to join/stay on the trial?
23-03-2013 10:18 PM
I'd love to see it as an option for my standard login as an opt-in option.
Cheers
07-04-2013 5:57 PM
Quote from: mikehiow Were there problems with the trial? If it was working for the trial, why not let customers choose to join/stay on the trial?
Plusnet had to cease the trial as they couldn't maintain it due to substantial network changes/upgrades.
Hopefully at some point those changes will be completed, and the trial can restart.
09-04-2013 8:09 AM
FWIW, the IPv6 trial was one of the things which made me switch to Plusnet, whereas it's continued unavailability certainly isn't encouraging me to stay...
Is there any sort of ETA?
Tim.
09-04-2013 9:28 AM
Quote from: TimSmall Is there any sort of ETA?
Indeed. Earlier posts by Plusnet staff implied a service trial date some time around Q4 2012. We're now in Q2 2013!
09-04-2013 9:29 AM
Ex-Plusnet Jobsbody
09-04-2013 9:35 AM
22-05-2013 11:02 AM
dick:quote
28-07-2013 12:07 PM
The NAT problem was never solved by IPv6.
28-07-2013 4:35 PM
Or by 'NAT problem' were you referring to something caused by NAT?
