Withdrawl of IPv6 Technical Trial
- Trials
- IPv6 Trial
- Withdrawl of IPv6 Technical Trial
Re: Withdrawl of IPv6 Technical Trial
08-10-2013 3:48 PM
08-10-2013 4:01 PM
08-10-2013 4:24 PM
08-10-2013 5:38 PM
08-10-2013 7:31 PM
08-10-2013 7:37 PM
08-10-2013 7:39 PM
Quote from: vilefoxdemonofdoom Will every device incorporate its own individual firewall?
No, why would they need to? The firewall will be in the router, just as it is now.
08-10-2013 7:45 PM
It would be interesting to know how many legacy IPv4 only routers, have firewalls that are otherwise transparent to IPv6 traffic.
This was another reason I wanted my network to be IPv6 ready, because at least I know that my internet connection has stateful filtering on both IPv4 and IPv6 packets.
08-10-2013 7:50 PM
08-10-2013 8:27 PM
08-10-2013 8:33 PM
08-10-2013 9:13 PM
That's sufficient to address 3.402823669×1038 computers.
08-10-2013 9:19 PM
08-10-2013 9:33 PM
Another benefit of the long address length is that it facilitates auto-configuration using a variety of unique identity sources. IPv6 has been deployed with a de facto standard of always using the last 64 bits as the host identifier and so in reality the address space isn't quite as large as first appears given this effective fixed delimiter of network:host on the 64th bit. Thus, even if you've only got a few devices on a LAN you would typically still allocate it a /64 subnet. That's a whole load of 'wastage' but is exactly how IPv6 is intended to be deployed and provides many benefits in doing so.
To summarise; the vast IPv6 address space exists not only to facilitate the unique addressing of a vast amount of devices but most importantly to be able to do so in a ordered manner that can still be efficiently routed.
08-10-2013 9:34 PM
I suspect this is fixed in newer IOS versions however.
