Tomato, WRT54GL and IPv6
- Trials
- IPv6 Trial
- Tomato, WRT54GL and IPv6
13-11-2011 12:10 AM
I have found a build of Tomato that supports IPv6
It is by toastman and can be found here: http://www.4shared.com/dir/v1BuINP3/Toastman_Builds.html#dir=92623834
The build I have used is: tomato-k26-1.28.7821MIPSR1-Toastman-ND-miniIPv6.trx
Will try it when I get home (at work at the mo). The only thing is under the setings for IPv6 when I select the service type as Native IPv6 From ISP it needs to know the following to configure it:
Assigned/Routed prefix, Prefix Length, Router IPv6 Address and entries for the Static DNS.
Any one from Plusnet able to confirm what these would be for the login I have?
1 REPLY 1
Re: Tomato, WRT54GL and IPv6
13-11-2011 2:36 PM
Hmmmmm. I get an IPv6 assignment from plusnet, I can ping6 and traceroute6 to ipv6.google.com with no issues from the WRT54GL, however I still get no IPv6 internet connectivity on Windows 7.
Anyone have any ideas as to why? My PC is getting an IP and gateway.
