(Split) Struggling to get IPv6 Up and Running
Epyon
Ok so running my DG384G in pure modem mode with the PPP session from windows
Test with IPv4 DNS record ok (0.891s) using ipv4
Test with IPv6 DNS record ok (1.009s) using ipv6 6to4
Test with Dual Stack DNS record ok (0.749s) using ipv4
Test for Dual Stack DNS and large packet ok (0.228s) using ipv4
Test IPv4 without DNS ok (0.404s) using ipv4
Test IPv6 without DNS ok (0.397s) using ipv6 6to4
Test IPv6 large packet ok (0.283s) using ipv6 6to4
Test if your ISP's DNS server uses IPv6 bad (1.638s)
Thats my main account
My test account well...it says it can't reach any IPv6 sites  Roll_eyes
13 REPLIES 13
MJN
Fixes: 5
Hi Epyon,
You appear to be using 6to4, a IPv6-in-IPv4 tunneling mechanism built into Windows. You might want to disable this with the following at a command prompt (run as administrator):
netsh interface 6to4 set state disable
This will force the use of your native IPv6 connectivity, which may well of course not be working given the apparent preference for using 6to4 in your tests.
Mathew
Epyon
Na native is just not working for me i guess  Angry
MJN
Fixes: 5
Happy to work through it with you if you like Epyon. Starting with the output of ipconfig /all at a command prompt would be good just to see what state it is currently in.
Mathew
Epyon
Any help is great and
this using my test account
Windows IP Configuration
  Host Name . . . . . . . . . . . . : xxxxx-pc
  Primary Dns Suffix  . . . . . . . :
  Node Type . . . . . . . . . . . . : Hybrid
  IP Routing Enabled. . . . . . . . : No
  WINS Proxy Enabled. . . . . . . . : No
PPP adapter Plusnet IPv6 PPPOE:
  Connection-specific DNS Suffix  . :
  Description . . . . . . . . . . . : Plusnet IPv6 PPPOE
  Physical Address. . . . . . . . . :
  DHCP Enabled. . . . . . . . . . . : No
  Autoconfiguration Enabled . . . . : Yes
  Link-local IPv6 Address . . . . . : fe80::108d:8c22:ca78:a2f6%28(Preferr
  IPv4 Address. . . . . . . . . . . : 81.174.168.153(Preferred)
  Subnet Mask . . . . . . . . . . . : 255.255.255.255
  Default Gateway . . . . . . . . . : fe80::90:1a00:3a3:ab3f%28
                                      0.0.0.0
  DHCPv6 IAID . . . . . . . . . . . : 477386784
  DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-13-67-E8-40-00-24-1D-CF-
  DNS Servers . . . . . . . . . . . : 212.159.6.10
                                      212.159.6.9
  NetBIOS over Tcpip. . . . . . . . : Disabled
Ethernet adapter Bluetooth Network Connection:
  Media State . . . . . . . . . . . : Media disconnected
  Description . . . . . . . . . . . : Bluetooth Device (Personal Area Netw
  Physical Address. . . . . . . . . : 00-0A-3A-81-EF-22
  DHCP Enabled. . . . . . . . . . . : Yes
Ethernet adapter Local Area Connection:
  Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
  Physical Address. . . . . . . . . : 00-24-1D-CF-F9-8C
  Link-local IPv6 Address . . . . . : fe80::4d64:cdc:ca6e:4086%10(Preferre
  IPv4 Address. . . . . . . . . . . : 192.168.0.4(Preferred)
  Subnet Mask . . . . . . . . . . . : 255.255.255.0
  Lease Obtained. . . . . . . . . . : 30 May 2011 16:08:24
  Lease Expires . . . . . . . . . . : 30 May 2011 20:59:20
  Default Gateway . . . . . . . . . : 192.168.0.1
  DHCP Server . . . . . . . . . . . : 192.168.0.1
  DHCPv6 IAID . . . . . . . . . . . : 234890269
                                      212.159.6.9
  NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.{D35DBEE5-91ED-4490-97ED-9249164E823B}:
  Description . . . . . . . . . . . : Microsoft ISATAP Adapter
  Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Tunnel adapter isatap.{BA58C600-9098-46AC-A367-E83BDB593969}:
  Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter Local Area Connection* 11:
  Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
  IPv6 Address. . . . . . . . . . . : 2001:0:5ef5:79fd:2898:3958:ae51:5766
erred)
  Link-local IPv6 Address . . . . . : fe80::2898:3958:ae51:5766%12(Preferr
Tunnel adapter 6TO4 Adapter:
  Description . . . . . . . . . . . : Microsoft 6to4 Adapter
  IPv6 Address. . . . . . . . . . . : 2002:51ae:a899::51ae:a899(Preferred)
  Default Gateway . . . . . . . . . : 2002:c058:6301::c058:6301
                                      212.159.6.9
Tunnel adapter isatap.{D51A408E-EF85-4E3C-B7CD-F9B021B823D5}:
  Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
brueton
I went back to my normal username, no ipv6.
After going back to the trial username it took a couple  of router reboots before ipv6 was working again, not sure why.
PB
MJN
Fixes: 5
Epyon,
First off, disable Teredo and 6to4 tunneling - they're only going to get in the way - by typing the following in a administratively-run command prompt:
netsh interface teredo set state disable
Next we should try enabling configuration through DHCPv6, however the the effectiveness of this may well depend on how well your modem is going to play:
netsh interface ipv6 set interface 12 advertise=enable managed=enable
See how that goes (rerun ipconfig /all). If this sounds like stabbing in the dark then I'm afraid it is... There's a steep learning curve for all here I think! Wink
Incidentally, are your modem configuration pages showing signs of IPv6 connectivity?
Mathew
Epyon
I'll try that
and yes according to the PPP session Internet on both IPv4 & 6.
Epyon
Ok well the last cmd would just error and no IPv6 pages working
  Host Name . . . . . . . . . . . . : xxxx-PC
  Link-local IPv6 Address . . . . . : fe80::108d:8c22:ca78:a2f6%12(Preferred)
  Default Gateway . . . . . . . . . : fe80::90:1a00:2a3:7791%12
                                      0.0.0.0
  DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-13-67-E8-40-00-24-1D-CF-F9-8C
  DNS Servers . . . . . . . . . . . : 212.159.6.9
                                      212.159.6.10
  Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
  Link-local IPv6 Address . . . . . : fe80::4d64:cdc:ca6e:4086%10(Preferred)
  DHCP Server . . . . . . . . . . . : 255.255.255.255
                                      212.159.6.9
I think i may need a ipv6 DNS server anyone suggest?
MJN
Fixes: 5
Quote from: Epyon
Oops - yes it would. My mistake.
You first need to find out the index number ('Idx') for your PPP adapter. Do that with the following:
netsh interface ipv6 show interfaces
Then you'll be able to execute the netsh interface ipv6 set interface <idx> advertise=enable managed=enable, replacing <idx> with the relevant number.
I'd suggest getting the native IPv6 connectivity sorted first, then you can look into sorting DNS out (DNS over an IPv6 transport is not a pre-requisite for IPv6 connectivity whilst you're still dual stacked).
Mathew
brueton
I would agree with MJN, your problem is deeper than DNS settings.
Here is my setup for DNS.
  DNS Servers . . . . . . . . . . . : 2001:470:20::2
                                      192.168.0.101
Copied from ipconfig /all - Windows 7
It is being picked up automatically, I did not need to set it up manually.
PB
Epyon
Its 12 but it says parameter is incorrect Sad
and yeah peteb my set up is different
I'm using PPP via windows and not my router since my router doesnt have support for IPV6
MJN
Fixes: 5
Can you confirm what version of Windows you're using?
Perhaps things are different when working on a PPP adapter - unfortunately I'm not nearly familiar enough with netsh to know my way around.
Mathew
Epyon
Windows 7 (64bit)
and yeah i think it is different.
