IPv6 packet loss on pcl-ag06
brueton
Is anybody else on the trial seeing IPv6 packet loss?
Gateway: pcl-ag06
IPv4
IPv6
4 REPLIES 4
brueton
Re: Packet loss only on IPv6
Seems to be a problem with the pcl-ag06 gateway.
I have moved to ptn-ag01 and the IPv6 packet loss has disappeared.
zpeterk
Re: IPv6 packet loss on pcl-ag06
Which ipv6 address do you use to get the ping monitor to work?
ie, pc or router
brueton
Router, then the ping monitor continues to work with the PC is off.
brueton
Still a problem  Sad
Gateway: pcl-ag06
IPv4
IPv6
