IPv6 Trial
- Trials
- IPv6 Trial
- Re: IPv6 Trial
IPv6 Trial
29-09-2015 6:19 PM
Hiya Guys. Would like to try IPv6 out. Whats the procedure?
Guy
Guy
1 REPLY 1
Re: IPv6 Trial
29-09-2015 6:47 PM
AFAIK the PlusNet trial isn't open to new participants - so you'll just have to wait (don't hold your breath) until they sort out the first "live" services.
In the meantime, you may want to head over to http://tunnelbroker.net where you can get an easy to use tunnel to get onlline right now. It;s also worth signing up for their "certification" which will force you to learn all the basics you'll need - a step at a time.
