IPv6 Trial Tests and Feedback
- Trials
- IPv6 Trial
- Re: IPv6 Trial Tests and Feedback
21-12-2013 1:14 AM
Quote from: jelv If you are not prepared to accept some extra effort may be needed on your part you shouldn't put yourself forward.
Plusnet applied selection criteria to get exactly who they wanted, the blame lies with them.
21-12-2013 3:09 PM
Ex-Plusnet Jobsbody
21-12-2013 3:43 PM
Quote from: DaveyH
Quote from: jelv
I am, that's why I've spent several hours this afternoon reading up and trying different things to get ipv6 up and running.
But a little bit more than just username and PW from plusnet would of been nice, an example of a working configuration as a starting point so I'm not fumbling around in the dark.
A trial is a trial. This sort of thing you have to expect.
I will be doing a guide for my router which is tomato firmware based, that might help others on other routers, however my migration date is it seems not until 31 dec and I wont get my ipv6 account until after that date.
Ipv6 does have its own form of dhcp but not all routers will support it.
21-12-2013 4:25 PM
But unlike ipv4 where all you really have to do nowadays in many cases is enter your login details and away you go, ipv6 clearly isn't, with even experienced people struggling to get up and running
Just some working examples to give an idea/starting point to work from
As an example of what i mean, i've been a satellite 'hobbyist' for years, and run Linux boxes and due to there nature i.e being highly customisable, you can end up with some unique problems, however i have found when i've run into problems , that while a problem might be particular to my setup, often i can adapt solutions others have come up with for similar problems into workarounds for my own use case.
Anyway apologies to all for yesterdays rant,
21-12-2013 5:04 PM
21-12-2013 5:33 PM
Quote from: MJN I can post my working config, ...... it is difficult to see how it is going to help you at all.
Agreed.
The easiest to get working is a TG582n running 10.2.0.B firmware. I had to change the username & password to the ones supplied for the trial.
A Billion 7800N running 1.06h needed a little more doing via the GUI. For other hardware / firmware configuration via the command line may be required,
I expect that all routers that are meant to be IPv6 capable will vary in how to set them up. Some will be impossible to get working at all and others will be as easy as my TG582n.
The version of firmware you a running may also make a difference.
I have found that the routers's command line can provide a lot more information and configuration options than the GUI. Sadly command sets appear to vary.
Wireshark running on a client will let you see any IPv6 traffic between it and the router.
There is a Router Advertisement test command (radvdump) for Linux that will let you see if an radvd daemon is running on the router.
26-01-2014 10:32 PM
Just wondering if there are any updates on the IPv6 trial?
Doesn't seem to have been much activity here for a bit........
What are the next steps?
What are/ are there any rollout plans?
Thanks,
Andy.
26-01-2014 11:06 PM
Like you I'd find the plans going forward of interest.
26-01-2014 11:40 PM
27-01-2014 8:44 AM
27-01-2014 8:59 AM
27-01-2014 9:41 AM
Phil
27-01-2014 10:04 AM
Yes, good points from you all.
However, as a relatively tech savy user with a collection of IPv6 equipment and my IPv6 ready router I'm keen to take a look.
It would just be nice to know when that will be possible, either as part of the trial or as part of a standard deployment. I certainly don't want to wait for a "standard" router that in all likelihood I'll put on the shelf with the other ones I've collected over the years.
Hopefully there will be options discussed and made available.
From your experiences so far it would seem that in most cases IPv6 could simply be enabled for all- if the router is not set up then IPv6 simply wont be used......
Looking forward to hearing more details!
Andy.
27-01-2014 10:12 AM
My android tablets will not download from play store (Amazon & onemobile are fine), my desktop fails on updates to some of Ubuntu's servers - although my LMDE install is fine (no Ubuntu servers on it). Web pages fail to load (FB & MSE).
The only way to fix the android is to disable IPV6 on it, same with the Ubuntu issue.
27-01-2014 10:35 AM
In terms of going forward, I dont think its necessarily a deal breaker on routers as by default routers will connect with ipv4 only, all the routers I have looked at that support ipv6 have it turned off by defaul, meaning connectivity would not break.
