Billion BiPac 7800N ipv6 configuration assistance needed.
ascent
Hi Guys,
I am having only limited success with ipv6 - I am part of the PlusNet ipv6 trial & I am using the trial login.
I have a Billion BiPac 7800N with v1.06e firmware.
Has anyone had any success with this router & if so, can you share the correct settings to use?
12 REPLIES 12
Fixes: 1,491
Re: Billion BiPac 7800N ipv6 configuration assistance needed.
I think there are a few threads about issues with this router, though it did work fine for me, so I believe it's a recent thing.
brueton
There appear to be some "issues" with IPv6 on the 7800N and Plusnet.
I and sjrinfroyle have posted in this and the Billion forums.
Plusnet forums
http://community.plus.net/forum/index.php/topic,97833.0.html
http://community.plus.net/forum/index.php/topic,100983.0.html
Billion UK forums
http://www.billion.uk.com/forum/viewtopic.php?f=9&t=46
http://www.billion.uk.com/forum/viewtopic.php?f=9&t=219
Edit: added links to other posts
PeteB
brueton
@dvorak
Is IPv6 still working for you with a 7800N? It was OK for me at first but problems started with the IPv6 maintenance carried out by Plusnet on 12/07/2011 http://community.plus.net/forum/index.php/topic,97228.0.html.
Edit: Added link to maintenance announcement.
PeteB
Fixes: 1,491
I gave up my space on the trial after a few weeks, it was working great and I tested everything I needed to so handed it back before the issues.
ascent
Thanks for the quick reply guys, but I was given my ipv6 login TODAY - I need some practical advice on actual settings.
If anyone knows what settings work well, or can provide a link to some help page it would be greatly appreciated.
Cheers.
brueton
I made notes on my setup. Can PM them to you if you wish when I get back home, will be late tonight.
IIRC put username & password in for normal setup, for IPv6 enable it. Can't remember navigation but documented it all.
BUT it used to work for me but no longer does unless I apply a manual fix via telnet.
The 582n I received today works OK.
Hope this helps.
PeteB
ascent
Quote from: PeteB
That would be great.. Thanks.
brueton
Can you get it working with IPv4 using the test login?
ascent
Quote from: PeteB
Yes I can..
I also managed to access some IPV6 sites, but it failed the tests on http://test-ipv6.com. I was using some blundering manual config settings that I'm certain were wrong.
sjrinfroyle
Quote from: ascent
What are the settings?
ascent
Quote from: sjrinfroyle
Quote from: ascent
I knew you were going to ask... I'll try & remember.
In Wan profile, I had ipv6 address set to "::". I have no idea what address it is picking up.
Here is how I show my ipv6 ignorance. My clients were not picking up a v6 address. To allow them, I set IPV6 autoconfig:
interface address / prefix length = fc00::/7
dhcpv6 server type = stateful
sjrinfroyle
What does the Billion status page show under gateway, netmask and Primary DNS?
