Billion 7800N: Not Working!
- Trials
- IPv6 Trial
- Re: Billion 7800N: Not Working!
22-12-2011 9:20 AM
Glad you got it working
22-12-2011 11:43 AM
Quote from: Ben Glad you got it working
Thanks to PeteB!
Ben, I think there seems to be some incompatibility between the Billion 7800N and the Plusnet RADIUS. As two users (PeteB and myself) have experienced this problem, other users could be experiencing it as well. Do you think I should email Billion to let them know or is it something for Plusnet to look at? I understand that this is the point of the trial to alleviate these problems before the product gets released.
22-12-2011 11:47 AM
22-12-2011 11:51 AM
Quote from: Ben I'd recommend you hold fire and test with the Technicolor 582n first, just to make sure there is an issue with the Billion.
Okay, I'll do that! Will it be sent First Class and will it be trackable?
Quote from: Ben Is there any documentation available to show what the Billion does actually support?
There isn't any as far as I am aware, IPv6 support was only added in a recent firmware update. After I've got the Technicolor in my hands I will be able to let you know! Does it have gigabit ethernet or 802.11N WiFi?
Once I get it I will need to get the target SNR reset to let me use it to it's max speed: As I tweak my connection a lot, this has caused the target SNR to go up, but with tweaking I have been able to get it down again. I have seen some good reports of line performance on this router so hopefully it performs well!
22-12-2011 11:55 AM
Quote Home networking experience will definitely change with the Technicolor TG582n. With an improved coverage and throughput compared to any 11b/g or 1x1 11n access point (from 54 to 65 Mbps), the Technicolor TG582n doubles the bandwidth and improves the link stability, coverage and coexistence with other access points in the neighbourhood.
The Technicolor TG582n is a high performant router: with a simultaneous operation of 802.11b, 802.11g and 802.11n 2x2, speed, security and performance are guaranteed. Featuring an integrated 10/100Mbps 4-port switch, the Technicolor TG582n offers seamless connection of wired and wireless devices from anywhere in the home.
The integrated modem supports ADSL, ADSL2, and ADSL2+.
So yes, it's Wireless N but no, it's not GbE.
22-12-2011 12:00 PM
Quote from: David So yes, it's Wireless N but no, it's not GbE.
That's not too bad. I am slightly disappointment at a wireless N speed of only 65Mbps when my Billion can do 130Mbps but I'll be able to test it in the real world when I receive it!
22-12-2011 12:01 PM
Quote from: sjrinfroyle Will it be sent First Class
Yes
Quote from: sjrinfroyle will it be trackable?
No
Quote from: sjrinfroyle Does it have gigabit ethernet
No
Quote from: sjrinfroyle 802.11N WiFi?
Yes
I've got one on my desk and it does pretty well... Still waiting for today's post though!
22-12-2011 12:03 PM
22-12-2011 12:24 PM
22-12-2011 12:41 PM
Quote from: Ben do you want to wait until you get the new router or go for it today?
First of all, thanks Ben! Did anybody ever mention that you are awesome? I'll wait until the new router arrives.
22-12-2011 12:47 PM
22-12-2011 12:48 PM
Quote from: Ben If you get the router tomorrow, drop me a pm
Will do. Has the post arrived yet
22-12-2011 1:20 PM
22-12-2011 3:05 PM
22-12-2011 3:39 PM
