BNG heavy weight in gateway selection
- Trials
- IPv6 Trial
- BNG heavy weight in gateway selection
19-03-2015 8:37 PM
Please either fix the BNG's to work properly on dhcp6 or remove them from the round robin on the ipv6 accounts, thanks.
5 REPLIES 5
Re: BNG heavy weight in gateway selection
20-03-2015 7:42 AM
Been working fine for me for the last 6 months.
20-03-2015 8:59 PM
for me if I select dhcp it allocates a different prefix. so it does work but allocates a different prefix.
If I try to manually configure the same ip that the non BNG allocates there is no traffic, its dead.
20-03-2015 9:51 PM
andy by the way do you know if can reconfigure ipv6 somehow manually without dropping ppp? as all I need to do to fix mine is probably make the router request the prefix from plusnet.
20-03-2015 10:34 PM
You can do it from telnet I think.
If you do it from the GUI, it restarts the DHCP/PPP daemons and will drop the connection.
21-03-2015 1:49 AM
so what commands you used?
at a guess I think I am missing an ipv6 gateway. I am assuming there is a way to trigger a dhcp refresh on ipv6 to kick start it.
