6in4 IPv6 Tunnel natively on Technicolor TG582n
- Trials
- IPv6 Trial
- 6in4 IPv6 Tunnel natively on Technicolor TG582n
Re: 6in4 IPv6 Tunnel natively on Technicolor TG582n
21-08-2012 9:18 PM
@taras - no wireless issues here (yet). iPhone and Android tablet connecting ok
and as MJN says. I previously had this working with HE's Tunnel Broker service.
23-08-2012 4:27 PM
I assume other people using 10.2.2.9 are using SMTP sendmail via relay.plus.net, if not can someone else try this please? The strange thing is I can telnet to port 25 and the server answers. So why does doesn't it work via the Mail app in OSX with the TG582n?
23-08-2012 7:09 PM
23-08-2012 11:21 PM
23-08-2012 11:42 PM
Mathew
26-08-2012 9:18 PM
Runs off to hid
05-09-2012 1:43 PM
I've now got two tunnels running simultaneously on the router, however it seems to have increased the IPv6 ping time, I'm not sure why, the IPv4 ping time is unaffected.
I don't think there is much point to two tunnels as I can only route traffic based on destination subnet, one of them is just used for ping responding, all the other traffic goes down the other tunnel.
06-09-2012 4:00 PM
I too have a problem with my android phone connecting to the router when I use 10.2.2.9, it connects OK with 10.2.0.B.
No joy with the ipv6 tunnel yet, I can ping IPv6 sites from the router OK, the PC gets an IPv6 address but does not ping any IPv6 sites.
Will try and investigate further over the weekend.
Pete
25-09-2012 3:12 PM
is it still 10.2.2.9?
thanks
luke
26-09-2012 1:13 PM
23-10-2012 2:37 PM
23-10-2012 9:28 PM
12-01-2013 3:33 PM
thanks very much for providing such a good set of instructions - you've managed to explain a pretty complex setup in nice easy(ish) steps, with a sensible breakdown so someone can check that each stage is working before moving onto the next.
I managed to register for a tunnel with SixXS and get a native IPv6 network up and running at home and routing to the Internet. All was well until earlier in the week when my external IP address changed, and at that point my tunnel stopped working. I logged onto SixXS and changed the tunnel endpoint to the new IP address, but its still not working.
Do I need to do anything on the router to reconfigure this? There's nothing in your instructions specific to the ADSL IP, so am slightly confused as to why its not working.
Should I really be on a fixed IP Address, and how do I request this if so?
James
14-01-2013 3:37 PM
How long had you been running this James? I found the router would randomly reboot usually at the most inconvenient of times and gave up with it.
14-01-2013 9:32 PM
thanks - have now got a static address through Plusnet. I've had this firmware on the router for about a week, and it hasnt rebooted on me as far as I can tell.
The other issue I had was the router losing these IPv6 settings when rebooting. I've now issued a 'saveall' command, which I'm assuming will save the router setup to flash. If this is the case, may be worth adding to the instructions.
James
