6in4 IPv6 Tunnel natively on Technicolor TG582n
spraxyt
Resting Legend
Fixes: 75
Re: 6in4 IPv6 Tunnel natively on Technicolor TG582n
Have you tried using the serial number of the router as password?
David
taras
Yup just tried:
password: serial number
And user:
Admin
admin
Administrator
And still no go. I have reset the router via the button on the back .
Picnic
Yeah I did a reset via the button as well. But that was while I was trying to program the new firmware without the router resetting all the time. It's definitely reset as the IP has gone back to 192.168.1.254.
I've got an access key on the base of mine which also doesn't work
Picnic
BINGO
username admin
password is the serial number (mine starts CP1213...)
it is case sensitive but I've just got in.
taras
Matt had to repair the router via tr69 :P.
Thanks matt Cheesy
taras
Oh dear the usb stuff has gone Shocked
mattturner
Hi Taras,
I'd forgotten about that, we only supply routers without USB ports so all the functionality is removed in our firmware builds...
I've got a copy of the original USB enabled firmware, I'll post a link shortly.
Matt
taras
Thank you matt Smiley
mattturner
Hi Taras,
A link for our original (including USB) firmware.
http://www.mattturner.plus.com/PN TG582n R844J +USB BW.bin
Thanks,
Matt
Picnic
Hmm, seems I still failing at all this. I can't get a connection to PlusNet with this latest firmware Sad
The error is simply "Concentrator not reachable". I'm on FTTC and I've been through the Connection Wizard and selected Other with a PPPoE connection. I have no idea how to use WAN-Sensing. There doesn't appear a means for me to select a particular LAN port for the WAN connection and auto sensing makes a progress bar move and that appears all. Any guesses on what I'm doing wrong. There are no messages at all in the log about attempting a connection.
Oh and why does configuring the WAN connection in the wizard reset the router's password, it's a real pain.
I think I'll have to change my forum handle to picnir (problem in chair not in router) Wink
mattturner
Quote from: Picnic
Hi Picnic,
This firmware isn't designed for FTTC, it won't work on FTTC without some significant configuration.
If you're interested in having a go then if you do a factory reset then run these commands everything should work fine. Not for the faint hearted though!
Matt
:ppp flush
:ppp relay flush
:eth flush
:atm flush
:atm phonebook flush
:eth bridge ifdelete intf=ethport4
:eth ifadd intf=eth_wan
:eth ifconfig intf=eth_wan dest=ethif4 vlan=default
:eth ifattach intf=eth_wan
:eth ifconfig intf=eth_wan wan=enabled
:ppp ifadd intf=Internet
:ppp ifconfig intf=Internet dest= eth_wan
:ppp ifconfig intf=Internet class=12 accomp=enabled mru=1492 format=none dnsmetric=10 idletime=0 restart=enabled
:ppp ifconfig intf=Internet ipv4=enabled ipv6=disabled
:ppp ifconfig intf=Internet user=yourusername password=yourpassword status=enabled
:ppp rtadd intf=Internet dst=0.0.0.0/0 src=0.0.0.0/0 metric=10
:nat ifconfig intf=Internet translation=enabled
:system config defaultconnection Internet
:system config WANMode ETH WANEthPort ethif4
Picnic
Thanks Matt, not really any more scary than the IPv6 Tunnel commands Wink I'll give this ago and let you know how I get on.
taras
As sixx still hasn't approved my application (they didn't reply to my previous email).
Can other staic ip 6n4 tunnel providers work ?
taras
I ended up going back to 10.2.0.B firmware as my mobile phones wouldn't connect to the wireless Shocked on the 2.29 version.
MJN
Fixes: 5
Quote from: taras
I'd suggest Hurricane Electric's Tunnel Broker service. Far better on a number of levels - they own their own equipment (no finger pointing when the POP falls over), no complicated credits system to allow you to 'buy' added features, automated tunnel creation and forums where you can openly discuss anything IPv6-related (including the tunnel service itself). Their certification programme (free) is worthwhile if you want some structure to learning and practising more about IPv6.
Mathew
