582n losing broadband and not reconnecting - SOLVED
brueton
Just so that those trialing the 582n routers with IPv6 firmware are aware.
After successfully using the 582n for a few weeks on my 21CN line I took it over to a friends house yesterday, she is with Plusnet on a 20CN line. I wanted to get a non-technical persons views on it and IPv6 although my guess is that she will not be aware that IPv6 is working on her connection.
I installed it and checked it was working at approx. 7pm last night. Before I had arrived back home at 8:20 pm it had lost the broadband connection and needed powering off and back on to reconnect. This also happened sometime overnight.
I will try and recover it on Sunday and see if I can work out what is going on. The old router which I will put back is a Netgear DG834PN, don't know if it was losing the connection but if it was it reconnected automatically.
I will try and get some router log files to see if they show what is happening.
PeteB
11 REPLIES 11
adamwalker
Fixes: 221
Re: 582n losing broadband and not reconnecting
Let us know if a factory reset doesn't fix that as we might need to provide a replacement.
 Adam Walker
brueton
It was supplied by Ben Trimble as part of the 582n / IPv6 trial and has test firmware. My next step is to try it again on my line, it did not have the problem when I tried it for a few weeks. I hope to recover it this weekend.
PeteB
BenTrimble
Yeah, no RMA's for these routers Smiley
(Not being mean or 'owt, they just don't appear on your accounts and only I have the firwamre!)
brueton
Any chance of a Visual RADIUS graph or graphs for the user for the last couple of weeks?
I can PM the Plusnet usernames, it was the standard login until about 7pm on Monday 16th Jan and then an IPv6 login.
PeteB
adamwalker
Fixes: 221
Sure, PM them over and I'll sort that out.
 Adam Walker
brueton
PM sent.
adamwalker
Fixes: 221
Sorted, I've replied to your PM Pete
 Adam Walker
brueton
Visual Radius graph shows the connection as being stable since the router reboot on Tuesday morning. At the moment I will consider the problem to have been a "one off" and will leave the router in place to see how it performs.
PeteB
brueton
Can I get another Visual Radius graph for the ipv6 test user so that I can check the stability of the connection. No further problems have been noticed.
Pete
jojopillo
Hi PeteB,
Looking good! Smiley
brueton
Many thanks. It looks af if the problem may have been with the line or at the exchange.
PeteB
