what type of phone is compatable with the Plusnet Hub 2
- Home Phone
- what type of phone is compatable with the Plusnet ...
12-12-2022 7:35 PM - edited 12-12-2022 7:39 PM
New kid on the block here, what type of landline type phone is compatible with the Plusnet Hub 2? No BT plug socket, only an usb socket.
Re: what type of phone is compatable with the Plusnet Hub 2
12-12-2022 7:41 PM
@KrisM Welcome to the forum. I'm a little confused with your final comment - you have to have a BT socket to be able to use the Hub2 - or any ADSL/VDSL internet connection.
12-12-2022 8:09 PM - edited 12-12-2022 8:10 PM
Are you connecting your Hub Two to a Full Fibre Openreach ONT or a Master Phone socket connecting directly to the port with a modem icon or using a ADSL filter connected to a standard phone socket?
If Full Fibre ONT then there is no landline option.
If using a phone socket any stand BT compatible phone would work, it would be connected to the ADSL filter or master socket faceplate phone socket
HTH.
12-12-2022 8:10 PM
Thanks, @Dan_the_Van - I should have asked that question - doh!
- Home Phone
