voicemail
sacha100
voicemail
Hi is it possible for my Voice mail to be switched off please, I did not activate it or requested it be switched on and have only today noticed that I had messages on the service.
I have my own answer machine so the plusnet voicemail service is not required.
Many thanks.
5 REPLIES 5
Kdog
Fixes: 9
Re: voicemail
Just give cs a call. It can be taken off though it takes a few days. Same happened with me-our lass works from home and the company she works with doesn't allow you to have voicemail on your line. It gets put on automatically on the BT end with any line with it as its a free service they assume you'll want.
sacha100
Re: voicemail
Thanks just seen that this can be done in the control panel now. just got to wait up to 3 days for5 it to be switch off.
Fixes: 1,587
Re: voicemail
It's usually a lot quicker than the quoted 3 working days to add or remove call features.
I can see it's been removed 20 minutes later. Thumbs_Up
sacha100
Re: voicemail
yep blinked and it was done, first class service plusnet keep up the good work.
SammyM
Fixes: 91
Re: voicemail
Hello @sacha100
Fantastic, please get back to us if you need any further assistance.
 Sammy M - Sheffield Team
