voicemail 4 rings?
mysticdz
voicemail 4 rings?
my home phone rings about 4 times before going to voicemail, is there a way to change it to make it longer as 4 rings is barely enough time to reach it before it stops
2 REPLIES 2
pwatson
Re: voicemail 4 rings?
Assuming you have the free 1571 service (and not an answering machine!) then you can't change the number of rings. To do so you need Voicemail Extra which is £3/month
http://www.plus.net/support/phone/call_features.shtml#voicemail
That said, I thought it should be 7 rings so perhaps there is a config error.  I don't use my PN line so I can't check...
198kHz
Fixes: 39
Just to confirm - yes, it's seven rings on the free 1571 service.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
