telephone line through window - being replaced -
mal0z
A friend with phone and broadband with PN, is having new windows installed - and the telephone passes through one of yhe  window frames.
So who is reponsible for getting the wiring moved out of the way ( probably cutting the cable )  - so frame can be replaced, and then the wiring restored.
Is the company doing the windows - and they need to contact Plusnet or BT wholesale ?
Or the property owner - contact Plusnet or BT ?
They also want the telephone wiring tided up and a new master socket provided .
many thanks
Mal#
12 REPLIES 12
Mand
Re: telephone line through window - being replaced -
Hi Mal,
I've tried calling you but there was no answer. Drop me a PM with a good time to call tomorrow.
There are a few options here.
Fixes: 356
When I had windows replaced they carefully cut the old frame around the cable, and then installed the new windows so that the cable was between the wall and the window.
mal0z
Thanks Mand - a PM on it's way.
Was that the call with number withheld - mid afternoon ?. If so why withheld - many people don't like that ?
MAl
Mand
It wasn't deliberately withheld, our phone just does that if I don't call from a standard CSC phone (calls from the CSC display the 0845 number).
198kHz
Fixes: 40
Quote from: Mand
It wasn't deliberately withheld, our phone just does that...
Not of its own volition - PN must have opted for "always withhold CLI" on that line. Like Mal, I tend to ignore 'withheld' calls.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
HPsauce
Quote from: MisterW
It's the only cost-effective way, you're not supposed to modify BT's cabling before the master socket.
It just needs a bit of care when removing the old window.
I'd also cut a bit of a channel in the brickwork and plaster (or whatever is round the window) once the cable is freed, so that the new windows can be installed properly and the cable sealed in effectively without needing to cut into the new windows.
Then deal with the "tidying up" as a separate exercise. It won't be cheap though.  Embarrassed
mal0z
OK thanks all. Seems like an 'internal move ' by PN/Openreach is the solution - put cable through another window already replaced.
Or as you say HP, drill a hole through masonary and put it through that.
thanks all
mal
jelv
Fixes: 10
I must admit when I first read this topic title I was curious as to what had upset you so much (my eyes skipped "line").
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
HPsauce
Quote from: mal0z
How much would that cost - any price been quoted yet?
Mand
A new install is cheaper to be honest.
It falls under the category of time related charges, which costs £85 - £100 for the visit (including first hour) and then £65 per hour after that.
A new install costs £49.99.
itsme
Quote from: mal0z
Could be wrong but I thought BT stopped going through window frames.
mal0z
Well spotted Jelv  Wink
I meant the telephone line of course.
Trouble with a new line - is that its a new number, and no doubt a minimum contract period - with line rental etc - so overall, it is bound to be more expensive ?.
and yes - going through a window frame esepcially double glazed ones - not best route, so masonary drill through wall and sealed after is much better idea.
I've passed info onto friend, and he says thanks, and when the work is planned will be in touch.
