remove answer phone
mikkykitten
remove answer phone
since coming to plusnet home phone and broadband im bombarded with the nuisance calls. Have caller id so can decide if i want to answer or not. but i cant work out how to turn off the plusnet answermachine facility.  dont want it as they just leave message, usuall a robot.
for Plustnet please disable my answerphone, if i want it on i have my own. thank you
2 REPLIES 2
ITWorks
Fixes: 9
Re: remove answer phone
Hi there
this can be done from your telephone control panel
click this link for more details on how to remove the voicemail feature  http://www.plus.net/support/phone/call_features.shtml
Regards Mike
mikkykitten
thanks...found the remove features tab.. all done...
