phone not ringing?
- Home Phone
- phone not ringing?
phone not ringing?
28-11-2020 1:32 PM
my house phone does not ring although you can pick it up as if its SUPPOSED to be ringing and can ring out
I know the first solution wold be to try another house phone... but i dont have this option unfortunately
and just wondered if someone cuould check my side before i buy a new house phone
thanks
Re: phone not ringing?
28-11-2020 2:21 PM
You can do it yourself here https://www.plus.net/help/phone/phone-line-troubleshooting/
I think you will need to try with another phone though to rule out your equipment.
28-11-2020 3:31 PM
Unless there is a fault showing on the line it needs to be tested from your end, is it possible to borrow a phone and plug it into the test socket?
Regards
3 weeks ago
I don't have friends nearby (closest is 15 miles away) , don't drive, I don't really speak to my neighbour as we have issues
so cant borrow a neighbours, maybe on up the street, but its a bit of an ask to someone you pass and say hello too every other day with quick 10 second chats...
all I can do is buy one and see if it works? if I ring the number by mobile, if I pick up I will be there- it just doesn't ring (the house phone but there seemed to be a connection?
thus possibly making iit sound like my equipment
