phone minutes
- Home Phone
- phone minutes
phone minutes
12-12-2007 3:09 PM
I have just had my home phone activated(yesterday) and the e-mail that I had today has confused me (not difficult). It says they are giving me an amount of minutes, 17397, to use up to my next billing date,(23/12/2007) and then in brackets says I will be charged for these minutes, cost, £5.81. I signed up for anytime +. Some clarification please anyone,
Message 1 of 4
(1,747 Views)
3 REPLIES 3
Re: phone minutes
12-12-2007 3:16 PM
The £5.81 is the pro rated fee to take your service upto your Broadband billing date.
The bit about the included minutes is wrong and needs changing (I'm about to raise this internally). It is also confusing where it talk about the charge for the minutes as this is actually the charge for your service and not your minutes as such, especially as there is no longer a limit on the number of minutes you receive.
Message 2 of 4
(610 Views)
Re: phone minutes
12-12-2007 5:37 PM
Thanks James, that's what I thought it all meant, but you can never be certain.
Message 3 of 4
(610 Views)
Re: phone minutes
12-12-2007 5:43 PM
Absolutely. You've also helped us to highlight an issue which will now get fixed
The problem I raised to Content has asked for the email to change references of minutes cost to service cost and also to removed the pro rated number of minutes, so thaks for that!
Message 4 of 4
(610 Views)
