phone charges
- Home Phone
- phone charges
Re: phone charges
09-06-2014 10:43 AM
I've had a look into your call charges and it seems like this is not happening every day that you call your daughter so we can only conclude that the calls that have been charged were connecting and you are therefore being charged for the first minute. There is also a call that lasted 3 minutes and 2 calls that lasted 2 minutes - all the other calls are 1 minute or under. If you have a look at your itemised bill it will show you the dates and times when the calls were made. Please bear in mind that even if the call goes to Voicemail it will count as the call "connecting" and it may be chargeable.
Re: phone charges
09-06-2014 11:42 AM
Hello Linn K,
yes, I am well aware of the actual calls to my daughter, and the applied payment costs for same. It seems you are actually repeating what has already been said in 'concluding ' that I have also been charged for the 'three rings ' I actually made for the first minute ! The issue in question, which you have already outlined was " why should any charge be made for ring tones ?? and no actual connection ? you point being that by just ringing I would be connected and therefore charged. . have already stated that I will NOT be using this 'method' again , at least not with the Plusnet system
Re: phone charges
09-06-2014 12:06 PM
Sorry if my previous post wasn't very clear - if you've been charged this would indicate that the call has "connected" in some way or another. Can you confirm if your daughter's mobile phone showed a missed call on the days that you were charged for 1 minute?
Re: phone charges
09-06-2014 8:26 PM
thanks for the continued interest. Unfortunately at the moment, I am unable to furnish the details you mention, from my daughter. However just to clarify things, just as soon as I can; I will let you know Thanks again
Re: phone charges
10-06-2014 1:27 PM
- Find something in your house that keeps accurate time without adjustment (e.g. a radio-controlled clock, or a computer) and which displays the time including seconds (we can help show you how to get that on your computer if you need it);
- Sit next to the timepiece above, with a pen, paper and your landline phone;
- Instruct your daughter to not answer her phone (perhaps by ringing her in advance to tell her you're carrying out a test);
- Dial your daughter's mobile from your landline, and when you start hearing ringing, take a note of the time including seconds e.g. 13:19:35;
- Eventually your call will be transferred to your daughter's voicemail. At the moment you hear that happen, take a note of the time again, e.g. 13:19:55;
- Wait a day;
- Log in to your Plusnet telephone control panel, click on the Recent Calls tab, and see which of the two times you wrote down is the closest to the time for the call shown online.
Like I say, I don't know for certain if that'll work (e.g. the times shown online could be inaccurate for some reason of which I am unaware), but it might be worth a try. I am assuming that the time given online should be the time at which the call connects (because that's when it should start to be chargeable), so if the time shown is actually the time the phone started ringing, there's a problem.
Re: phone charges
10-06-2014 2:41 PM
Thanks for the interest and for the suggestion.. Since my last 'letter' from Linn of Plusnet I have checked back on my phone account with Plusnet, and there appears to be a few 'time' discrepancies along the lines you suggest eg: 16-05-2014. 0900 :56 1 min 26p.. 16-05-2014.. 0901:00 1min 26p.. again,
13-04-2014. 0859:03 1min 26p.. 13-04-2014 0859:56 1min 26p...? there are a few more instances, but as you see , there is something very wrong , especially since I am being charged for each . ! ( note the actual times and dates duplication ?)..) Yes, I have a radio controlled clock, but I must confess, I am a bit loathe to give them the chance to take more money from me.. Without 'timing' , I just let the phone ring three times precisely, and dissconect.. All in all Be3G, I have just not bothered to go thr'u the practice again. There just will not be anymore 'ringing ' from my landline to her mobile again . Rip off, comes to mind..?
Thanks again Be3G .....best wishes
Re: phone charges
10-06-2014 4:05 PM
I've asked a member of our Networks team to have a look into this and they can confirm that the call on 16/05/2014 that started at 09:00:14 lasted 12 seconds so you were charged for 1 minute as it's rounded up by the minute. The next call was then made at 09:01:00 and lasted 68 seconds so you were therefore charged for 2 minutes.
To clarify: If you make 5 calls within 1 minute that all connect and the duration is under 1 minute you would be charged for 5 minutes.
The information is correct and showing that the call connected and how long for. It may be because your daughter's mobile was turned off or it could've gone to Voicemail.
Re: phone charges
10-06-2014 6:34 PM
Quote from: robbo6457 ... at least not with the Plusnet system
Quote from: robbo6457 Rip off, comes to mind..?
For fairness and clarification, it is not the PlusNet system which is causing you to be charged. It is the BTOR phone network which receives the call answered status which initiates billing. The billing details are then passed onto PN for onward charging to the subscriber. As per one of the links I gave above, it is either the target mobile network operator or an intermediate network operator which is falsely generating the call answered status.
Just a passing thought, has your daughter's mobile number been ported from one mobile provider to another or on diversion (call forwarding) to another number? I wonder if this condition is arising from calls being routed across provider networks based on the "STD" code to the original number owner and then at the point of redirection to the new number owner, the call answered status is being generated.
There ought somewhere in the industry be a means of investigating what is happening here, rather than just relying on the billing operator simply having to accept whatever "comes over the wall" from BTOR's call management systems.
Re: phone charges
11-06-2014 9:31 AM
I've heard plenty of anecdotal reports of this happening but I've never been given enough information to be able to chase it down (the specifics of our contract with BTWS, from whom we buy calls, does not help either). A colleague is taking over my responsibilities for the call rating platform so I will point him in the direction of this thread and ask him to pick up investigation from here.
Re: phone charges
11-06-2014 9:56 AM
Quote from: robbo6457 my daughter tells me she has a Nokia phone and a contract with Tesco !!
So potentially a Tesco issue or one with the O2 network (although my stepson is on GiffGaff and we don't get charged for unanswered calls to him)
Re: phone charges
11-06-2014 10:01 AM
Quote from: DomS So potentially a Tesco issue or one with the O2 network
And, if a number has been ported from another network then you have another possible source for the issue (add yet another if the number was ported from a different virtual network).
Re: phone charges
11-06-2014 10:08 AM
Re: phone charges
11-06-2014 10:27 AM
Mobile 1 - same number with Virgin since 1999 - never been ported = No connection charge for unanswered calls.
Mobile 2 - with Orange / EE since beginning of this year - never been ported = No connection charge for unanswered calls.
Mobile 3 - with GiggGaff for a year - never been ported = No connection charge for unanswered calls.
Re: phone charges
11-06-2014 10:30 AM
Potentially if the original poster gave his daughters number to a member of the DCT (with her permission), they called the number themselves, verified there was no answer then were charged, would that be enough proof to push it further with the suppliers ?
Re: phone charges
11-06-2014 10:45 AM
