no phone since yesterday
- Home Phone
- no phone since yesterday
22-10-2014 2:19 PM
Hi Is anyone working to fix this? I have opened a ticked but not heard anything regarding a fix
any info should be appreciated
Message 1 of 5
(871 Views)
4 REPLIES 4
Re: no phone since yesterday
22-10-2014 2:32 PM
Could you post the ticket number here.
Message 2 of 5
(449 Views)
22-10-2014 3:42 PM
Thanks for posting. I've found your account and run a line test. I'd like to be able to be sure what tests have been done though. I've placed an update on there, but I do require a little further information about the fault. Can you confirm if you've been able to try a different corded telephone into the main socket? Also, if you have one, can you try plugging the phone into the test socket. If you are not sure on how to do this, please post here and we will advise further.
Thanks,
Tony
Thanks,
Tony
Message 3 of 5
(449 Views)
22-10-2014 4:06 PM
yes I have tested with a corded telephone at the test socket and theirs no dial tone.
Message 4 of 5
(449 Views)
22-10-2014 4:12 PM
Message 5 of 5
(449 Views)
