no dial tone
ukjam
no dial tone
hi all ive just joined plusnet and my broadbands fine but my home phones not working properly theres no dial tone but I can ring out ok but theres no incoming calls. ive tried the help section but still not working the trouble shooter just says oops some thing went wrong any help would be appreciated so I don't have to bother there call centre
11 REPLIES 11
BrightonRock
Fixes: 8
Re: no dial tone
Welcome to the Forum @ukjam
The phone troubleshooter has a tendency to Oops! It may still have worked.Log in to your account and see if a fault ticket has been created.
ukjam
Re: no dial tone
just checked nothing raised there
BrightonRock
Fixes: 8
Re: no dial tone
Hmm. Worth trying again?
Otherwise, I think you are going to have to phone in. Or try Twitter. You may be lucky and a Staffer picks up your post here but they are stretched thin.
Geoff2055
Re: no dial tone
hi,
    Same issue. Have tried phone checker five times and got oops every time. Tried the 0800 number three times and it is currently down. This is really not good enough as there should be staff able to work remotely to cover any issues that are out there. i don’t use twitter and am finding that the live chat is also not working. So what next!
BrightonRock
Fixes: 8
Re: no dial tone
Welcome to the Forum@Geoff2055 It is often better to start a new tread rather than joining an existing one as the answer to one problem may not be the same as to the other.
That said, disregarding the oops, has the troubleshooter system created a fault ticket in your account? Not here on the Forum but the account at Plus.net.
I outlined the options to @ukjam for getting help you won't get anywhere with live chat as it is no longer working.
EmilyD
Fixes: 117
Re: no dial tone
Hi @ukjam,
I'm very sorry for the inconvenience that the landline fault is causing you and for the trouble that you've had with getting in touch with us. Having checked your account, I can see that you have now been able to discuss this with our technical support team and an engineer is due to investigate this fault on the 15th of April.
 Emily D
EmilyD
Fixes: 117
Re: no dial tone
Hi @Geoff2055,
I'm sorry to hear that you're also experiencing problems with your landline. I've tested the line but the test isn't picking up any problems from here at the moment. Is it the case that there's no dial tone at all on your landline and have you experienced any problems with your broadband connection whilst this has been ongoing?
 Emily D
Geoff2055
Re: no dial tone
There is no dial tone when we pick up the phone to dial out. There has been a drop in the broadband connection. On a couple of occasions the connection has been lost when we have received an incoming call. I have tested the line and did insert a micro filter. The broadband seems to be a little better but it has made no difference to the problem with the dial tone.
plusnettony
Plusnet Staff
Plusnet Staff
Fixes: 18
Re: no dial tone
I've taken a look at your account and note this has been raised for you. I hope it's resolved soon. Tony.
 Tony T
Geoff2055
Re: no dial tone
Hi, after a week of reasonable internet, still no dial tone On cordless phone and just received an incoming landline call and the internet dropped, with the router flashing red before returning to blue. So issue no resolved. Have kept micro folder in place even though the guide says not necessary. Any chance that this will resolved sooner rather than later.?
adamwalker
Fixes: 221
Re: no dial tone
Hi there, it looks like we need to arrange an engineer visit for you. I've added an update to your account re ticket 200934102. Please let us know when you've responded.
 Adam Walker
