my phone line isnt working but my internet.
- Home Phone
- my phone line isnt working but my internet.
29-11-2014 12:35 PM
B.t. have been working in my area .has this caused the fault on my phone. I have carelink which i need my phone for. My neighbour has the same problem with her phone
Message 1 of 5
(947 Views)
4 REPLIES 4
Re: my phone line isnt working but my internet.
29-11-2014 1:20 PM
Hi Kell1950,
Welcome to the forums.
It sounds like there is a local fault. If you can see BTOR engineers working in the area I'd go and ask them if there is a local live fault they are working on.
Ideally you need to report this to PlusNET over the phone (use the 03 number if ringing from a mobile which charges for 0800 numbers) however there could be a wait.
Is your neighbour with BT? If yes, then get them (work with them) to ues BTOR's online fault reporting. Also if you know someone with a BT phone, you could ask them to report an issue with ringing YOUR number. In days gone by the BT operator would test call the line and report any identified fault.
What do you hear if you try to ring your number?
Is the broadband ADSL or FTTC? If FTTC that points to a major cable fault. If ADSL it could be anywhere and expect it to fail anytime soon as your phone line us working on only one of the two wires
Message 2 of 5
(382 Views)
29-11-2014 3:17 PM
Hi kell1950,
Sorry to hear about the issue with your line.
I can see that you've called us this afternoon and that the fault has been reported with our suppliers.
Hoping to see that fixed soon for you.
Message 3 of 5
(382 Views)
30-11-2014 2:25 PM
Hi I wonder how long "soon " is? I haven't had dialling tone since Thursday 27th and yesterday I heard that the outside fault couldn't be mended until 9th December. Is this what Plusnet call "no compromise on service" I have now lost my internet service and have resorted to a neighbours internet provider to send this message.
Message 4 of 5
(382 Views)
03-12-2014 12:29 PM
Hi hillclimber,
I'm sorry to see the fault is taking a few days longer than anticipated to get fixed.
The lead times on engineer visits for faults are determined by engineer availability in your area.
Message 5 of 5
(382 Views)
- Home Phone
