most recent calls update
ruthe
how quickly does the "most recent call" (next to "most recent bills") update please? I made a call about this time yesterday (around 3 -4 pm) and left a message on a voicemail. I want to check time and length of call, but it is not there
8 REPLIES 8
Christopher_G
Fixes: 5
Re: most recent calls update
Hi @ruthe
Welcome to the community.
The calls are calculated every 24 hours, so it should update within 1-2 days.
Chris
ruthe
Thank you for your reply Christopher. It seems to be updating a bit more slowly at the moment as it is still not there?
Fixes: 384
@ruthe Was the call to a national (0102/03) number or a free one (0800/0808)?
ruthe
It was to a mobile, I remember hearing the voicemail message. It's still not there which is strange! I'm having a bit of a dispute with a company and just wanted to make a note for my records.
Fixes: 384
Have subsequent calls appeared?
ruthe
I don't think I've made any subsequent calls. I don't use my landline much. The last call listed is on the 13th November, which is probably right.
Fixes: 384
Four days is a bit of a long gap. Unfortunately, as this is all automated, I  don't think there is much anyone can do.
ruthe
Ok. Thank you very much for your help anyway. Hopefully I won't need it!🙂
