making local calls
- Home Phone
- making local calls
making local calls
20-09-2013 10:35 AM
some of the local numbers I ring work perfectly but others I have to input the area code in order for the phone number to be recognised
is this a problem with PlusNet's phone system or is it just a bug with non BT numbers not being routed correctly ?
not wanting to open a fault for it until I know if its normal
Re: making local calls
20-09-2013 10:41 AM
20-09-2013 11:05 AM
but that suggests the changes wont happen until next week (for the trial), besides that I live in taunton which isn't listed as one of the exchanges
20-09-2013 11:09 AM
20-09-2013 11:55 AM
20-09-2013 12:07 PM
20-09-2013 1:26 PM
the reason I'm wondering about it is the normal numbers (old ones) worked just fine and they start with 3/4/5 but there old BT circuit numbers that have been around for 10+ years.
also I'm fairly certain my landlord uses an LLU contract for there connectivity (because there mobile's are part of the bundle with short dial numbers)
it could well just be a side effect of the works being done to extend the number pools of local numbers available but it does seem a bit strange not to have had an announcement stating its happening ...
20-09-2013 2:42 PM
20-09-2013 3:06 PM
20-09-2013 3:40 PM
i'll just use full dial code +number when I use the phone in future
