loose cable from pole
- Home Phone
- Re: loose cable from pole
31-03-2015 9:04 AM
The cable from the telephone pole to my house seems to have worked its way loose in the storms over the weekend and is flapping about in the wind. Is this something I report to Plusnet as I get line rental through them?
Message 1 of 8
(1,796 Views)
7 REPLIES 7
31-03-2015 10:01 AM
Yes, but don't expect a quick response from BT if the line is still working...
Message 2 of 8
(1,255 Views)
31-03-2015 10:12 AM
If it's low enough to grab, then it's a problem if the ol' copper thieves (who'll be out in force today after last night's winds!!) see it and snatch it...
Message 3 of 8
(1,255 Views)
31-03-2015 11:15 AM
Message 4 of 8
(1,255 Views)
31-03-2015 11:23 AM
these are the parameters for reporting direct to Openreach https://www.openreach.co.uk/orpg/home/contactus/tellussomething/tellus.do and it would appear that your loose cable comes into that category
Message 5 of 8
(1,255 Views)
31-03-2015 12:03 PM
@plusnettony. It's waving quite merrily in the wind but too high for anyone to reach (about 3-4m). But considering I share a border with a primary school and it's perilously close to getting caught on their fencing, then I'd hope they might consider it so!
@oldjim Thanks, I'll check that link out. Should I also report formally to Plusnet?
Message 6 of 8
(1,255 Views)
31-03-2015 12:14 PM
reported it to Openreach - thanks Oldjim - and they are going to send someone to inspect within 24 hours. Waddya know, there are benefits to living next to a primary school
Message 7 of 8
(1,255 Views)
31-03-2015 12:50 PM
Can we have our ball back
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Message 8 of 8
(1,255 Views)
