line dead
- Home Phone
- Re: line dead
line dead
02-05-2014 10:54 PM
hi mods
how can I raise a fault ticket on my phone line , everything working fine then next time I come to use my phone the dial tone goes on off on off , BB working fine , no extensions etc coming off the master socket no alarms no sky nothing
I havnt even been with plusnet a week yes that's correct less than a week and the phone is playing up , 1st time in 20 years and then a transfer and it goes down , not happy
Message 1 of 5
(713 Views)
4 REPLIES 4
Re: line dead
02-05-2014 11:01 PM
You have a voicemail message, try dialling 1571!!!
Message 2 of 5
(316 Views)
Re: line dead
02-05-2014 11:10 PM
ahh thanks .... how do I turn it off
Message 3 of 5
(316 Views)
Re: line dead
02-05-2014 11:19 PM
ahh sorted cheers for pointing that out
mods can you close this posting thank u
Message 4 of 5
(316 Views)
Re: line dead
03-05-2014 8:55 AM
Just a check - did you turn voice mail off (via Call Features or did you just listen to/delete the message (leaving the feature active)?
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Message 5 of 5
(316 Views)
