landline fault
graememallan
landline fault
My landline wont make or receive calls since this morning, though broadband is working.
Sitting in q for ages now trying to report, with online chat out of action.
Tried troubleshooter test but that isn't working either.
Would appreciate earliest contact and resolution from plusnet.
Thanks.
1 REPLY 1
BrightonRock
Fixes: 7
Re: landline fault
The troubleshooter can be temperamental and record a fault while giving an error message. Check in your account for tickets; any ticket generated can be found here Tickets
If there isn't anything there you could try https://faults.plus.net
Other than that, try making a complaint using the link right at the bottom of the page "Complaints Code of Practice". What you have isn't really a complaint but that route seems to attract attention.
Please let us know how you get on.
