keep home phone after landlines are discontinued
rehtnap2023
will i be able to keep my landline on plusnet with viop when the bt landlines get cut off?
2 REPLIES 2
Mustrum
Fixes: 81
Re: keep home phone after landlines are discontinued
Fixes: 102
@rehtnap2023
No
If you want to keep your phone number while staying with PN you need to port the number to ab independant VOIP provider within 30 days of FTTP going live. You do not start the port until FTTP is live.
