incorrect telephone number?
- Home Phone
- incorrect telephone number?
15-10-2011 9:36 PM
Re: incorrect telephone number?
15-10-2011 9:41 PM
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
16-10-2011 12:25 PM
16-10-2011 1:08 PM
Just hang up after the lady reads your number back to you.
16-10-2011 8:19 PM
Please enter your Telephone Number (e.g. 01234123456) Or Service ID Or Both , below then click on "Go" to start the performance test.
Telephone Number
Service ID
Authorisation failed Incorrect Telephone Number - Please try again
Just seem too coincidental with leaving BT and moving over to Plusnet.
dick:quote
16-10-2011 9:20 PM
16-10-2011 9:59 PM
Quote from: pierre_pierre does the BT adsl checker work? https://www.btwholesale.com/includes/adsl/main.html
Number recognised on that link ok.
28-10-2011 11:35 PM
31-10-2011 7:51 AM
Quote from: galaxy66 I have just tried to test my broadband speed on BT's speedtester and it states it is an incorrect telephone number?
Just happened to me, although I ran a test last night without a problem. I also dialled 17070 to confirm that my number, or my memory of it, had not mysteriously changed overnight. So this must be a BT problem. I'm with BT for phone and Plusnet for broadband, by the way.
The exact error message is "Authorisation failed Incorrect Telephone Number - Please try again".
31-10-2011 8:18 AM
31-10-2011 9:12 AM
Quote from: ReedRichards The exact error message is "Authorisation failed Incorrect Telephone Number - Please try again".
Hour and a half later, I no longer get the "Incorrect Telephone Number" message, just one stage further to "The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider."
31-10-2011 9:47 AM
@ joesoho,
I'm concerned about what you've mentioned and can see that a fault is open at present. Feel free to give me a shout if you have any issues with that.
@galaxy66,
I've just tried running some tests on your line and couldn't find any issues. I'm guessing if you call someone with caller display that the correct number shows there too?
EDIT: I've just spotted a post from another customer who's had the same issue so it seems that we need to raise that with our suppliers.
- Home Phone
