how do I add line saver without calling up
chrcoluk
The FAQ says a vague can add via member centre but I find no option.
4 REPLIES 4
Oldjim
Fixes: 63
Re: how do I add line saver without calling up
chrcoluk
thanks, you know how to get to that page from the member centre?
Oldjim
Fixes: 63
nope - I have it bookmarked
essenby
@chrcoluk
  • Log in to the Member Centre and type "Line saver" into the Search box.
  • Select the first result (https://www.plus.net/home-broadband/line-rental-saver/)
  • Scroll down to wehere it says "Existing customers Simply log in to your account and select Line Rental Saver and reduce your monthly bill."
  • Click on "Log in to Member Centre" and you're there
Wink Wink
