home phone call log
- Home Phone
- Re: home phone call log
home phone call log
15-04-2024 12:03 PM
How do I access my home phone call log, try as I may I cannot find it. Also Plusnet take a black mark for no email contact.
thanks
15-04-2024 12:59 PM
Calls made each month are listed on page 3 of your bill.
15-04-2024 3:40 PM
I don’t have Plusnet telephone service anymore having gone FTTP.
From memory and as @Baldrick1 says calls start on page 3 of your bill. Recent calls made after the billing date are listed under ‘unbilled calls’ but again from memory I think there is a day or two lag between making a call and it appearing in the list.
15-04-2024 4:23 PM - edited 15-04-2024 4:24 PM
If you login into plusnet members centre, from Home click on >Phone, scroll down you should see
As previously mentioned "Most recent bills" will have your call log on a monthly basis, hopefully "Most recent calls" is what it says!
I can not check if it works as I don't use a landline phone, that's for scammers to call me on
15-04-2024 9:30 PM
Slight clarification, from the Home page you may need to select ‘More’ to get to Phone when using a small screen.
a month ago
Thank you,
