fraudulent use of home phone line/number
- Home Phone
- Re: fraudulent use of home phone line/number
17-03-2015 7:15 PM
17-03-2015 7:30 PM
17-03-2015 8:09 PM
17-03-2015 9:04 PM
http://www.whosenumberisthis.co.uk/09041961198
Looks like fraud rather than a crossed line.
17-03-2015 11:24 PM
18-03-2015 11:48 AM
I'll post again if anything happens. Plusnet does not seem able to do anything other than check with BT that the call was made.
18-03-2015 12:28 PM
19-03-2015 5:18 PM
This matter is already being dealt with by our support team. If you could please supply them with the crime reference number, it may help them with their investigations.
Thanks.
27-03-2015 3:34 PM
My concerns are twofold:
How do I get the money refunded? and
How do I get premium rate numbers barred from my line?
I have asked about a refund and was told you can't give me one
I have just had an online chat with someone and was told that you are not able to bar premium rate numbers. How then can I be certain that this won't happen again? I am thinking about taking my business to a company which can bar these numbers.
Thank you
27-03-2015 7:29 PM
It can't be guaranteed that this won't happen again, but it's unlikely. I'm running a line test now just to double check everything. Please keep an eye on the bill in the short terms and check to ensure you calls are being added correctly.
28-03-2015 6:39 AM
Quite worrying if this can be done.
28-03-2015 9:22 AM
28-03-2015 9:31 AM
I suspect either two ways, one would be to tap into a line between the customer and exchange - extremely easy to do especially if you are only targeting a random line. Secondly would potentially be to spoof the CLID so the recipient system thinks a different number is calling.
28-03-2015 10:24 AM
Thanks for your input
Basset
28-03-2015 10:39 AM
Quote from: Townman ...and if that can be done, call barring is not going to help, as the call was not dialled,
Depending on the method used possibly not, but a customer has got a much stronger case to argue that the call can't have been made on from their premises if barring is in place
- Home Phone
