disable 1571 voicemail
FIXED- Subscribe to RSS Feed
- Home Phone
- disable 1571 voicemail
- « Previous
- Next »
Re: disable 1571 voicemail
24-09-2019 1:56 PM
Hi @clesser, thanks for getting in touch.
We've requested the removal of this for you now. Please allow up to 24 hours for this to take effect.
Let us know if you need anything else
18-03-2020 7:37 PM
Could the 1571 voice mail feature be disabled on my account as well please?
23-03-2020 12:24 PM
Can the voicemail service be taken off my account, please?
31-03-2020 11:46 AM
31-03-2020 1:41 PM
Thank you, sorted now!
10-04-2020 2:07 PM
10-04-2020 10:43 PM
Hi, we also have an phone with answermachine so need to turn off the plusnet 1571 voicemail. Unfortunately the marked fix in this thread (back in 2012) does not work now - although there is a dashboard for adding/removing line features, voicemail cannot be removed this way as there is no tick box to remove it. Please could you help? Many thanks
10-04-2020 11:43 PM
@mannersh Welcome to the forum. 🙂
1571 cuts in after 7 rings, so as a temporary measure, can your answering machine be set to cut in sooner?
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
11-04-2020 7:20 PM
@198kHz Thank you for that tip - we have checked our answermachine settings and it is now set to kick in after 5 rings. We've tested it and the phone's built-in answermachine is now working. Thanks for the quick fix! We would still prefer it if 1571 voicemail is turned off though - no rush at all. Hope you have a good Easter and stay safe.
11-04-2020 11:40 PM
@mannersh Thanks for update. Be distant - and safe. 🙂
- « Previous
- Next »
