disable 1571 voicemail
abails0105
Fixes: 60
Re: disable 1571 voicemail
Hi @clesser, thanks for getting in touch.
We've requested the removal of this for you now. Please allow up to 24 hours for this to take effect.
Let us know if you need anything else
 Alice Baillie
ian2134
Could the 1571 voice mail feature be disabled on my account as well please?
Oldie
Can the voicemail service be taken off my account, please?
MatthewWheeler
Fixes: 480
@ian2134 Thanks for getting in touch. That's been requested for you now and should be removed within the hour
@Oldie I can see you requested this yourself and it's no longer active.
Let us know if theres anything else we can help with
 Matthew Wheeler
ian2134
Thank you, sorted now!
adream
mannersh
Hi, we also have an phone with answermachine so need to turn off the plusnet 1571 voicemail. Unfortunately the marked fix in this thread (back in 2012) does not work now - although there is a dashboard for adding/removing line features, voicemail cannot be removed this way as there is no tick box to remove it. Please could you help? Many thanks
198kHz
Fixes: 41
@mannersh Welcome to the forum. 🙂
1571 cuts in after 7 rings, so as a temporary measure, can your answering machine be set to cut in sooner?
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
mannersh
@198kHz  Thank you for that tip - we have checked our answermachine settings and it is now set to kick in after 5 rings. We've tested it and the phone's built-in answermachine is now working. Thanks for the quick fix!   We would still prefer it if 1571 voicemail is turned off though - no rush at all.  Hope you have a good Easter and stay safe.
198kHz
Fixes: 41
@mannersh Thanks for update. Be distant - and safe. 🙂
