cant decide weather to change
Hi Grin
Ive been with BT for EVER!!! but the new pricing on Anytime 240  looks appealing at £9.99/month. At the moment my monthly bill to BT inc E+W calls is about £24.00/month Im not sure what the 240 refers to.  Could anyone help explain this .Im also on prem op1.
Thanks Kiss
Craig P
9 REPLIES 9
Legend
Fixes: 168
Re: cant decide weather to change
We don't offer Anytime 240 any longer AFAIK, it was replaced with Evenings and Weekends. This means all your calls to standard UK landlines are included as long as they are made during evenings or weekends.
thanks for the info
it's the anytime at £15 a month that looks the dogs Smiley
ive seen that one but dont make that many calls during the day only the odd mobile call i tend to use the voip mins with prem 1 instead.  im not sure that it will save me much
well if you take the evening and weekends one then it's £9,99 a month
you get BB phone for anytime and landline for off peak it's a really awesome combination
i think i might go for that on at £9.99. Smiley  ill just have to make sure that the rest of the clan use the BB phone during the day Cheesy
thanks for the help all.  ive just gone for the E+W pakage at £9.99.  Looks like the best deal for me
Thanks again
Craig p
i'm in the process of getting mine sorted Smiley
and why does tha clan have to use bbphone? do you not use vent or teamspeak? heh even MSN messenger would do the trick, or the voice app on steam, all bar MSN would get titanium priority as recognised gaming protocols
not sure wat these are? im willing to learn though.  all for saving a bit here and there you know!! any info would be great.  Thanks Smiley
craig p
