can you turn off call return?
- Home Phone
- Re: can you turn off call return?
17-03-2015 10:11 AM
This is not the first time I have done it but when listen to my messages on 1571 I accidentally press the 3 button and then get charged for returning the call yesterday I got double charged because it was a mobile number I was phoning!!
So just asking can i turn off call return or assign it to a different number?
thanks
thanks
Message 1 of 8
(1,741 Views)
7 REPLIES 7
18-03-2015 10:10 AM
On 1571, pressing '3' will delete the message.
One assumes, then, that you're referring to the call return facility on 1471, which is also accessed by pressing '3'.
Apparently it can be disabled if you're with BT - see here.
As with other facilities, it may not be available with Plusnet - I don't know.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
Message 2 of 8
(1,046 Views)
18-03-2015 12:04 PM
Message 3 of 8
(1,046 Views)
18-03-2015 4:57 PM
Quote from: Force On 1571, pressing '3' will delete the message.
Yes you are right I mean 1471!!
I have just tried 1471 and it says the service requested is not available.
I still want 1471 just not the press 3 to return a call service.According to the link above you can turn off just that feature on BT so you should be able to on plusnet.
So is it possible to have 1471 without the press 3 call back service?
thanks
Message 4 of 8
(1,046 Views)
18-03-2015 5:11 PM
Message 5 of 8
(1,046 Views)
19-03-2015 4:24 PM
Did you manage to sort this out?
If not i will have to have 1471 with the call return option.
thanks
thanks
Message 6 of 8
(1,046 Views)
19-03-2015 5:08 PM
Message 7 of 8
(1,046 Views)
19-03-2015 5:13 PM
Quote from: ngfletcher1967 According to the link above you can turn off just that feature on BT so you should be able to on plusnet.
That's not quite what it says
Quote you can bar the use of Call Return ‘press three’, by using one of the options in BT Call Barring... There is an additional charge for this service
Despite years of asking by many people, Plusnet do not offer call barring as a (configurable) service, but there are ways for Plusnet to do it thmselves, Matt should be able to advise on what Plusnet can do in that regard.
Message 8 of 8
(1,046 Views)
- Home Phone
