caller identification
stathe
does not work so how  do i  make this work, and do i have to  pay extra with the any time package,  was o.k with b.t
10 REPLIES 10
pwatson
Re: caller identification
Caller ID costs £0.99/month and is enabled using the Telephone Control Panel
http://www.plus.net/support/phone/call_features.shtml
stathe
Quote from: pwatson
I thought it was included in my Anytime package
jim:green quote fixed mod:end
Oldjim
Fixes: 63
Nope and never has been which is a cause for many grumbles on here
stathe
Do you mean to say I have to pay extra for this basic facility
Strat
Fixes: 565
Surprisingly...yes.
Many around here consider it should be a standard feature...myself included.
jelv
Fixes: 10
The trend is for more and more features to be excluded so that the headline advertised price can be as low as possible.
BT will (from tomorrow) stop providing BT Privacy at home with caller display for free  (although you can have it free for a year if you commit to a new 12 month contract). It will cost £1.75 a month which makes the Plusnet £0.99 look good value.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
stathe
Well as a new Plusnet  phone user I hope I wont have more shocks as Im not really sure what the cost of my package is yet  Plusnet Anytime with unlimited broadband,though I have paid line rental in advance
ThatJeffAgain
Primus is £2.50 extra for caller display . I know this because i just bought a call blocker and have just found out it needs caller ID to work properly, which in my opinion. negates the use of a call blocker.
picbits
Unless their billing system throws a wobbly, you'll find PN are pretty competitive and you shouldn't have any shocks.
Yes the 99p CLID is a bit of a bugbear from me and they did increase the cost of my anytime package by 50p a month last year (which also caused a bit of an outcry) but gave the option for me  to break the contract as part of the increase T&Cs
Not any worse than the majority and better than many hence why I've gone for another 12 months LRS with them.
stathe
Thanks for the information
