caller display
FIXED- Subscribe to RSS Feed
- Home Phone
- caller display
31-03-2020 3:15 PM
I have been with PlusNet for over a Month now and I still don't have caller display. With coronavirus playing havoc with your call centre the customer service is a bit of a joke.
Fixed! Go to the fix.
Re: caller display
31-03-2020 6:12 PM
Thanks for getting in touch @DavDan
I've looked into this for you and I can see that it's showing as active.
Can you try dialling *#234# from the phone that you want to use for caller display and advise what message is read back to you?
Re: caller display
01-04-2020 12:17 PM
Same for me - been a customer for months - assume Caller Display was never activated on my line.
Plusnet Support - please correct this.
Re: caller display
01-04-2020 12:47 PM
Thanks for getting in touch @chrisparker
It looks like the feature wasn't active on our supplier's end.
I've placed an order to change this and it should be working now.
Let us know if there's anything else we can help with
Re: caller display
02-04-2020 5:54 PM
No joy on that I'm afraid, the voice message reports that the feature is unavailable. Do you have any other ideas? Thanks for your efforts though.
Re: caller display
04-04-2020 12:26 AM
Hi Matthew, the *#234# still doesn't work. "service requested is unavailable" , do we have any other options? I appreciate your efforts but I'm not getting any joy on this.
Re: caller display
04-04-2020 2:45 PM
I have the same problem with *#234# and *234# both reporting the service as unavailable. From this post and previous posts it appears that caller display has not been activated. Please can Plusnet remedy this and activate Caller Display.
Re: caller display
06-04-2020 2:44 PM
Re: caller display
06-04-2020 4:14 PM
Thanks Matthew. I’ve just tested Caller Display and it’s now up and running fine. Thanks again..
09-04-2020 3:29 PM
Thanks Matthew, caller display is now up and running.:-)
Re: caller display
09-04-2020 5:32 PM
Can this be fixed for my phone also please? I raised a ticket / support question.
Re: caller display
11-04-2020 1:40 PM
Thanks for getting in touch @simkar
I can see our support team have picked this up for you this morning and it should now be resolved
Re: caller display
06-06-2020 7:48 PM
Hi, I also don't have caller display working. I only transferred over to Plusnet this week so would suggest that this has not been activated. Could you please advise.
Regards
