caller display activation?
- Home Phone
- caller display activation?
06-12-2013 10:34 AM
Hi
My phone line got activated today and it works fine but caller display isn't working on my handset, it just says "External Call" can this be manually activated perhaps?
Also just to confirm I did request when i placed my order and am paying for caller display too.
Thanks.
Thanks.
Message 1 of 8
(875 Views)
7 REPLIES 7
Re: caller display activation?
06-12-2013 10:46 AM
Sometimes there is a short delay and sometimes it gets stuck - there has been a history of such issues with the BT backend systems.
One of the DCT members should be able to check, but they are very busy at present. It might be more proficient to raise a support ticket on the matter.
Message 2 of 8
(223 Views)
06-12-2013 11:14 AM
Hi brummies,
I've taken a look on our systems and on our Suppliers Systems which shows that Caller ID is active. Does this not work on any incoming calls at all?
Message 3 of 8
(223 Views)
06-12-2013 11:29 AM
Nope not working, tried using two different mobiles too to test it out..
Message 4 of 8
(223 Views)
06-12-2013 11:43 AM
I've raised a case with our suppliers to have this investigated for you. We'd expect an engineer to have looked into this within 24-48 working hours.
Really sorry for the inconvenience caused.
Message 5 of 8
(223 Views)
06-12-2013 1:10 PM
I've just heard back that our suppliers believe the issue has been resolved, could you double check that this is the case please?
Message 6 of 8
(223 Views)
06-12-2013 5:36 PM
Just to confirm it works fine now after testing it.
One more question can you confirm that still is ex directory?
Thanks again
Thanks again
Message 7 of 8
(223 Views)
09-12-2013 11:58 AM
Hi, yes I can confirm the line is still set as ex-directory
Message 8 of 8
(223 Views)
