caller ID active / not working
- Home Phone
- caller ID active / not working
13-11-2013 6:13 PM
Second day of plusnet after moving from sky, my account says caller id is active but it isnt working. Sky worked fine. Have tried everything sugested by plusnet website. I need it working. I'm quite disappointed.can anyone help
Message 1 of 6
(1,007 Views)
5 REPLIES 5
Re: caller ID active / not working
13-11-2013 6:51 PM
I had the same issue - it appears something gets a bit stuck on the BT systems and while it appears to Plusnet that it is enabled, it isn't.
You might just want to pop a note you're having the same problem on the end of this thread so it gives the guys who have dealt with it before a notification that you have the issue
http://community.plus.net/forum/index.php/topic,111545.0.html
Message 2 of 6
(457 Views)
13-11-2013 6:52 PM
Welcome to Plusnet by the way
Once you get any initial niggles sorted it's usually pretty much plain sailing
Message 3 of 6
(457 Views)
14-11-2013 9:32 AM
Hi cbennyjones,
I've checked over your account and can see that Chris Pettitt has placed the order for caller display.
Message 4 of 6
(457 Views)
14-11-2013 3:52 PM
Thank you. Superb customer service, very unusual these days.
Message 5 of 6
(457 Views)
14-11-2013 3:59 PM
See - they're not a bad bunch really
Glad you got it sorted
Message 6 of 6
(457 Views)
- Home Phone
