call records do not get updated
- Home Phone
- call records do not get updated
27-04-2010 10:17 PM
are plusnet's systems as slow as the bb order completion process (~1 month?)...
Re: call records do not get updated
27-04-2010 11:08 PM
And some call to New Zealand are a problem, due to a change at their end
28-04-2010 9:45 AM
see reply #76
28-04-2010 10:02 AM
@pierre_pierre, the New Zealand issue is fixed, as per my post here.
@Reserved, we've done some refactoring work, and are just testing the results, so you should see a massive improvement from now on.
@ritz, we're up to processing calls from the 26th (so calls made up to the 25th). We should catch this up later today. I'll check that we've got the call data for you, and will update you in a few minutes.
28-04-2010 10:25 AM
mand, i finally got updates this morning, which at first glance look alright.
as there seems to be quite some literature and (a rather concerning) history on the matter, are there any plans for a better billing, call logging system?
28-04-2010 10:28 AM
28-04-2010 10:38 AM
@reserved, as far as I can see you've only made one call since, on the 27th (which will be processed today).
28-04-2010 10:40 AM
Quote from: Mand @reserved, as far as I can see you've only made one call since, on the 27th (which will be processed today).
Blimey - the wife must have got a sore throat
28-04-2010 10:45 AM
I've had a developer check the database and that's the only call we've got for you currently. However, international or non-standard calls will take longer to get to us from BT.
28-04-2010 10:51 AM
- Home Phone
