call divert
Rich7
call divert
Hi can someone please tell me the code to turn off call divert on the website it just says code what code do you use please.
Rich
6 REPLIES 6
198kHz
Fixes: 42
Re: call divert
'Code' means 21, 61 or 67, depending whether it's
All calls (21)
Calls not answered in 15 secs (61)
Divert on busy (67)
BT technician (Retired)
Rich7
Re: call divert
thanks for your time but how do I turn it off I don't want it at the moment.
Rich
Fixes: 383
Re: call divert
@Rich7 Try #21#
Rich7
Re: call divert
no still on, even though it says its off it still diverts any more suggestions I think it may be time to chuck it over the hedge.
198kHz
Fixes: 42
Re: call divert
Which of the three types of divert did you initially switch on?
Rich7
Re: call divert
61. to divert to a mobile.
it seems to have worked itself out I no longer have the intermittent tone.
I don't think I bother with it again.
It seems a poor service if it answers after 15 seconds, I would have preferred to be able to change the divert time to longer.
Thanks for everyone's help.
Rich
