answering machine
- Home Phone
- Re: answering machine
answering machine
13-01-2008 5:00 PM
since moving my phone from bt/onetel to talk talk and then onto plusnet
I have found that my answering machine does not work properly.
has anyone had similar problems?
ps it is not the machine as I bought an identical machine and the problem was still there.
13-01-2008 5:36 PM
Is the machine connected via an ADSL filter/splitter?
In what way does it not work properly. I presume you mean it does not answer calls? if so, have you checked to config to see if things like answer after so many rings is set or can be set.
14-01-2008 10:05 AM
We see this a lot with lines moved from Onetel or Talk Talk.
The issue is likely to be something called proprietary voicemail, which often tends to cause problems because BT Wholesale 1571 cannot override this.
The quickest way of resolving this is to contact Talk Talk and ask them to add and then remove proprietary voicemail, then add our voicemail once this is removed.
A pain I appreciate, but it does seem the quicker way to resolve this from recent experience.
14-01-2008 9:56 PM
it stopped working when switched from one tel to talktalk and the fault has remained when transferred to plusnet
the machine is connected via an adsl filter.
the problem is that the answer is triggered but at the point of "please leave your message after the tone" there is no tone and
the machine runs on till the end of its recording time without recording anything
re mand
does that mean i cannot use my answer machine and have to use voice mail?
thanks again for the replies
14-01-2008 10:52 PM
It's highly unlikely that moving to PN would cause this - the line etc. used is identical to a BT retail line. It's more likely to be either a defective machine, it's been configured wrongly or there's something amiss with your wiring
How many other phones etc. have you on the line? Have you exceeded the REN for the line? Have you tried a different make of answer machine?
Mand was referring, I believe, to voicemail giving problems and not physical answering machines.
I've had lines from BT, TalkTalk and PlusNet and my answering machine has worked on them all.
16-01-2008 10:07 PM
i dont thinkit is the machine as i bought an identical one and the problem persists.
when i transferred to talktalk the company did llu at the exchange and the problem seemed to appear after that. i was unable to get talktalk to do anything and i had hoped when i went to plusnet the problem would have been solved.is it possible that the llu procedure could have caused the problem?
16-01-2008 10:14 PM
09-02-2008 7:45 PM
09-02-2008 9:11 PM
If the answering machine does work in the master socket, but not when you plug in the lower half of the master socket, then there are other tests we can suggest. trustnoone - it will help if you answer all of Paul_B's questions, to help eliminate possible sources of the problem.
16-02-2008 12:17 PM
