Your Home Phone order is currently being processed
- Home Phone
- Re: Your Home Phone order is currently being proce...
12-09-2014 9:56 AM
Hi
I am still getting this message in the Home Phone Control Panel. It seems to be an issue this week, as I see others also have the same.
The Phone service went live on 9th Sep.
Could you assist me also - not sure if you need further info?
FC
FC
Message 1 of 7
(1,475 Views)
6 REPLIES 6
Re: Your Home Phone order is currently being processed
12-09-2014 11:24 AM
Hi Fairchino,
This has been raised has a problem as you are not the only one.
I will make sure that your Home Phone Control Panel is activated for you by this afternoon at the very latest.
Thanks,
Matty
Thanks,
Matty
Message 2 of 7
(976 Views)
12-09-2014 12:04 PM
Many thanks for the response Matty.
I have received an update via the Support Team.
"We've been unable to place the order for your phone service.
Our support team will look to resolve this. You don't need to do anything."
Do I need to ask if they could actually do a bit more than look?!
FC
FC
Message 3 of 7
(976 Views)
15-09-2014 2:51 PM
That will have been when I was tampering around with your account to make it reflect the same status.
Sorry about that, our systems tried placing your phone order again and then got confused because you were already with Plusnet.
Hopefully, everything should reflect properly from your perspective now.
Message 4 of 7
(976 Views)
16-09-2014 9:14 AM
Hi Matty
I can now access the control panel - so think all is as it should be.
Could you check I'm still on the terms I agreed with Plusnet - as per Ticket #90612658? The Account details section is showing differently, but I assume that's just the way the system works...
Many thanks again
FC
Many thanks again
FC
Message 5 of 7
(976 Views)
16-09-2014 9:58 AM
Hi Fairchino,
It seems that Matty's tampering caused the Line Rental Saver to not reflect on the account showing that your broadband was being charged as an account without phone. I've rectified this now so everything should be correct as per the details in Ticket: 90612658.
I've created Ticket: 91644295 confirming your account details in full. Apologies for any inconvenience and confusion caused. If there's anything else at all just give us a shout!
Message 6 of 7
(976 Views)
16-09-2014 12:08 PM
Thank you Lynn
That ticket is in my language and pretty clear!
The control panel is showing correctly now also.
Appreciate the efforts of you both.
FC
FC
Message 7 of 7
(976 Views)
- Home Phone
