Wrong Flat connected (?)
- Home Phone
- Re: Wrong Flat connected
30-10-2012 10:35 AM
I ordered the fibre and home phone package yesterday, the homephone service was connected today, but they have connected the wrong flat, I'm at 37b.
We dont have a phone in our house atm, so my flatmate rang the number provided and it rang, no one answered but it must be that downstairs flat was connected rather than us.
Need help with this asap!
30-10-2012 10:40 AM
Can you hear the phone ringing downstairs
30-10-2012 10:43 AM
What was the date you were told you would have it connected?
30-10-2012 10:44 AM
Everyone from the flat are at work atm so we don' know for sure, just don't want to cause any annoyance to the lady downstairs, we've just moved in - dont' want her to hate us
30-10-2012 10:46 AM
Then I got an email this morning saying that it's ready and gave us a number. The fibre installation isn't until November 13th-ish
Re: Wrong Flat connected (?)
30-10-2012 11:06 AM
30-10-2012 11:10 AM
30-10-2012 11:12 AM
In this case, we will have detected a stopped line, which we can activate the same day, depending on the time we submit the order.
This process is completely reliant of the accuracy of the address you provide us. According to the selection made, we were not provided with the "b" as part of your address.
I can see that you have raised a ticket related to this and our provisioning team will review this accordingly.
30-10-2012 11:14 AM
Will this be any problem? I wont have to re-order the package or anything will I?
And do you think that the downstairs flat has been connected rather than us then?
30-10-2012 11:27 AM
I don't know what the process is, but I'd suggest you need to talk to Royal Mail to get them to list the flats separately to avoid similar problems in the future.
30-10-2012 11:30 AM
We will need our provisioning team to investigate further.
There are indeed possibilities that the wrong address has been hooked up. Address 1, 1a, 1b are three completely different things and given that your address has a "b", but the selection did not contain this, we just don't know.
I presume you have a BT socket in your property?
If you hook a phone up, does it have a dialtone? (though you wont be able to use it)
There may be a few options available, but it needs to investigation to take place first.
Some of these may involve us raising a fault on the line, others involve us placing a new order for the line which may take as long as a day, or several weeks depending on the need for an engineer. We will communicate more about the action needed, when we know more.
In all scenarios though, you will not need to create a new account with us. We will be able to use the existing account perfectly fine. We will perform all the needed magic internally to reflect any changes caused by fault or orders needed to correct it.
30-10-2012 11:41 AM
30-10-2012 11:47 AM
30-10-2012 11:51 AM
Quote from: jelv I'm afraid this is down to you as there's no way Plusnet or BT would be aware that there were separate flats as you didn't give them details that uniquely identified your flat.
There were 2 properties on the plusnet availability checker, likewise for BT but they did differentiate and had option a and b.
I added my address manually but I got completely different speed predicted to both 37 listings, the manual address got 5mbps, the other two 38mbps. I've noticed this inconsistency with every ISP I've tried
