Withhold number
forum_user
Withhold number
I'd like my phone number withheld unless I dial 1470 first.
How do I turn that feature on?
Fixes: 385
Re: Withhold number
I've placed an order to activate that for you now.
Can you check back in couple of hours time? Smiley
forum_user
Re: Withhold number
Yes, that's sorted - thank you!
Fixes: 385
Re: Withhold number
No problems at all Smiley
hc72
Re: Withhold number
I've just rung in about this and told this service wasn't available! It would be much easier for me instead of having to remember 141 every time I phoned a business. Please can you turn this on as well for me?
Fixes: 13
Re: Withhold number
Hi @hc72
I've placed this order on your line.
I'll check up on it in a few hours to see its progress.
Hope this helps.
Alisdair
 Alisdair C
Fixes: 13
Re: Withhold number
This is now showing as completed on our systems @hc72
All the best,
Alisdair
 Alisdair C
Wombat-UK
Re: Withhold number
Hello Plusnet Help Team,
Could I also please request that my CLI number is normally withheld when making calls, but allowing prefixing with 1470 to let the CLI through on individual calls.
Thankyou.
Fixes: 190
Re: Withhold number
@Wombat-UK I've requested this for you and it should be up and running within the hour.
 Matthew Wheeler
Wombat-UK
Re: Withhold number
Thankyou Matthew,
I've just tested this and it is working.
Regards
Fixes: 385
Re: Withhold number
Glad to hear that!
Let us know if you have any further queries.
