Will adding Anytime Calls package affect my broadband bill
gabthoms
Hi, I am currently on a discounted rate for my broadband and am on the free evenings and weekends phone package. I would like to change my phone package to the anytime calls package but do not want to mess up my discount on my broadband. Can I add anytime calls without losing my discount on broadband?
Thank you
3 REPLIES 3
daveplus
Fixes: 10
Re: Will adding Anytime Calls package affect my broadband bill
No, but you can double-check by going to the Product Change page in the Members Centre and try the effect of adding it.
spraxyt
Aspiring Legend
Fixes: 75
There is always a risk that changing your package will remove currently set discounts even though the discount is applied to the broadband and not the phone component. However if that happens I'd expect Plusnet staff here to add them back for you.
If you want to add Anytime Calls I suggest going ahead. It will take effect on your next billing date.
David
MattyC
Fixes: 46
Hi gabthoms,
This should not affect your broadband discounts at all. However let me know if you have any problems.
Matty
